Nous sommes actuellement le 26 Oct 2026, 06:45
Voir les messages sans réponses | Voir les sujets actifs
Retour sur Conan-chandelier » Index du forum » Bla-bla
Page 1 sur 1
[ 1 message ] |
| Auteur |
Message |
Shermankt
Sujet du message: RC-5 Mini USB LCD Display Screen Temperature Data Logger Rec Publié: 07 Nov 2016, 07:38 |
Inscrit le: 01 Oct 2015, 18:31 Messages: 1 Localisation: Germany
RC-5 Mini USB LCD Display Screen Temperature Data Logger Recorder RC-5 Mini USB LCD Display Screen Temperature Data Logger Recorder
Description : RC-5 Mini USB LCD Display Screen Temperature Data Logger Recorder This data logger is mainly used for temperature recording during storage and ocean/air/highway transportation of foodstuff, medicine, chemicals and other products, especially widely used in all kinds of warehousing, logistics and cold chain, such as refrigetated containers, refrigerated trucks refrigerated package, cold storage, laboratory, etc. or in large-sized global supply chain businesses. It has a large permanent data memory of 32000 points and comes with data management software for easy data download to computers through USB interface. With the software, you could analyze data in form of tables and graphs and export in picture format. The data could be queried, saved, printed and exported in Word/Excel/TXT /PDF format. Features : 1. Wide measuring range, high accuracy and large permanent data memory. 2. Data management software included for working with PC easily. 3. Data can be downloaded, analyzed, exported and printed conveniently. 4. Over Temperature Alarm & Upper/Lower Limits can be set. 5. MAX/MIN values available. Specifications : 1. Temperature measuring range : -30 C~+70 C; Resolution : 0.1 C 2. Accuracy : 0.5 C(-20~+40); others, +1 3. Temperature unit : or optional 4. Record capacity : 32000 points (MAX) 5. Record interval : 10s~24hour adjustable 6. Sensor : Internal NTC thermal resistor 7. Communication interface : USB interface 8. Waterproof grade is IP67 9. Power supply : CR2032 battery(included) or power supply via USB interface, and it could upload data even if the battery is out of use. 10. Battery life : in normal temperature, if the record interval sets as 15 minutes, it could be used above one year. 11. Item Size : approx. 80 (L) x 34 (W) x 14 (H) mm 12. Item Weight : approx. 30 g Package includes : 1 x RC-5 Mini USB Data Logger 1 x CR2032 battery 1 x Software installation CD Details pictures :
New Price 16.99 USD!
key:#66gDF%EdsagKUYUF#
_________________ http://shop6.olivertwist.ru/jiabosi-ori ... or-xiaomi/
Page 1 sur 1
[ 1 message ] |
Utilisateurs parcourant actuellement ce forum : Aucun utilisateur inscrit et 1 invité
Vous ne pouvez pas publier de nouveaux sujets dans ce forum Vous ne pouvez pas répondre aux sujets dans ce forum Vous ne pouvez pas éditer vos messages dans ce forum Vous ne pouvez pas supprimer vos messages dans ce forum Vous ne pouvez pas insérer de pièces jointes dans ce forum
